turn signal problem
ok well this has happened several times in the past. when i turn on my car my airbag light will stay on for like 2 min. and my turn signal wont work but yet if i turn the car off and then back on everything works just fine and the airbag goes off after like 10 seconds. has anyone else had this problem? and is it just the turn signal switch?
just turn the key back a little when its running...turn it back just enough to not shut the car off....that will fix the problem....
it doesnt do it when you turn off the car and then back on because you are not putting it in the same position....
try it....go out...start the car...turn the key back a little and there you go...problem fixed
i had this problem with my 95....its not the turn signal switch...its sumthing with the ignition
