lotsa performance questions
ORIGINAL: spudsterier
are you sayin that if i get a new pcm then i wont have to worry about the sentry
As far as the 2.4 mount, just let me know when and I can get one for you.
what size injectors?????
i think that i might just build up my motor...i think that would be alot of fun...im gona try and get a price for getting it bored within a few days.....unless i get a 2.2 stroker crate motor from howell.....but what i was wondering..what makes it a 2.2...or a stroker...dont know anything about it..jut sounds fun..
might go nitrous too
lookin at the walboro fuel pump......now modernperformance says its an intake module....is this one different then the rail mount??? or a miswrite???
checked out the regulators....anything still good, but cheaper????
well then i guess i could get some of these things.....i have decided that mi just goin to build up my motor...then i can even start buying it bit by bit.....i should find out about the turbo in a few days, currently im bidding on a mopar bov, and stock intercooler, and some autometer gauges, and then whatever else....i just cant buy too much right now since i should be geting my allignment today and putting my rims on, i just wanted to check these posts before i go mount the tires on the rims......
went to the motor guy a while ago and found out that it is gonna cost me 450-500 bucks to get my motor bored out....but the price includes: some hot tub cleaning thing(which is supposed to completelty clean the block, and whatever else i bring in), bore and hone, all prep needed, remove and replace freeze plugs, resurface the head, 3 angle valve job, replace valve guides, polish crank, and one other thing but i dont remember what...and they will also install the pistons and rings for me...i dont know if this is a good price or not, but sounds good to me
today really sucked because i went to get my tires mounted on the srt rims this mornin...figured i would just bring them in so i dont have to mess with it, ends up the 3 used ones i got from my friend cant be mounted because the inner sidewall is bubbled....the guy said they arent worth mounting.....so now i have to wait another week until i can get my new tires and put them on the car...i think imma order them tomorrow hopefully[:@]
