fog lamp replacement
on the passenger side you have to reach up behind the radiator support and there is 1 nut that hold the whole lamp on...loosen it and pull the assembly out the front....then twist and replace....
as for the drivers side....it is basically the same thing but there is a rectangular box in the way...you have to reach above the box and remove the two 10mm bolts....pull it down out of the way and the rest is the same from there
