roll cage
Old Aug 6, 2006 | 06:51 AM
superneon135's Avatar
superneon135
Default roll cage
hello does any one have an scca roll cage in there neon? if so about how much $$$$ did it run you, i am looking to get into rally racing with my 96 dodge neon i have just about every thing i need to hit the track. or does any know of a site with some pics any info will help
Old Aug 6, 2006 | 07:15 AM
Mruf's Avatar
Mruf
Default RE: roll cage
Check this page for info on building your rally neon: www.rallynotes.com
Also, the SCCA isn't the sanctioning body anymore. I think the national governing body is RallyAmerica, plus you will have local series rules.
Old Aug 6, 2006 | 10:27 AM
NYG's Avatar
NYG
mruf is correct - SCCA spun Ralley off
My original cage was a bolt in and ran about $900 (installed myself)
My new cage is welded (Much Better) and ran me about $1600
The welded is much better as it helps stiffen up the car for turning - I notice the bolt-in flexed with the car.
The Welded one also seems to be lighter - not sure how much if any - my car empty (No driver - No Gas) is 2600lbs with the Welded cage. when I had the bolt in it weighed approx 2690lbs.
I am thinking about moving my neon to Ralley racing after it expires from Club racing. I will be making that decision around the end of 2007. I will either move the car from SSC to ITA and keep on club racing or move it into Ralley racing!
Old Aug 6, 2006 | 09:16 PM
superneon135
the weld in one did you weld your self or did you have it done for you?
Old Aug 7, 2006 | 01:57 PM
NYG's Avatar
NYG
I had someone else weld it for me - as I do not have the expertise or experience to weld it myself.
Well worth the Money - Car Performance Increase was drastic as the car lost alot of its flex. I was able to keep all 4 wheels on the ground better through out the turns!
Old Aug 7, 2006 | 02:03 PM
das2123's Avatar
das2123
ORIGINAL: NYG
Yeah, but a pic of a neon on 3 wheels is cool to see!
Old Aug 7, 2006 | 05:42 PM
Mruf's Avatar
Mruf
How about on 0 wheels! [sm=crossbonesgif.gif]
Old Aug 7, 2006 | 05:51 PM
das2123's Avatar
das2123
LOL...NICE!!!
Old Aug 9, 2006 | 01:20 AM
NYG's Avatar
NYG
Wow - that out does my little 1 wheel off the ground
[IMG]local://upfiles/4417/6DCEFFCD9C0C46B0921CB37EB9763F67.jpg[/IMG]
Old Aug 9, 2006 | 02:03 AM
01dodge's Avatar
01dodge
I highly rec. welding in your rollcage. not only does it make your car more solid but safer to.
check out this web sit , it shows me going over turn 3 @ 55 and rolling at least 2 1/2 times stoping
on roof. I walked away with 1 little blk&blue mark under my arm from the seat. After rolling , it wasn't bent and no cracks in the welds
http://www.youtube.com/watch?v=2t44FbOShu0
