motor problems!!!!!!!!
Old Aug 10, 2006 | 08:20 PM
das2123's Avatar
das2123
Default RE: motor problems!!!!!!!!
ORIGINAL: mmench
could a large amount of carb cleaner hurt the map senssor cuz i did clean it all out with alot of cleaner after i blocked the egr valve
If it isn't "sensor safe" it's possible. I have heard of people having problems after running carb cleaner, Seafoam, or Mopar CCC through their system.
There is a link to the codes in the FAQ up top
Old Aug 10, 2006 | 09:52 PM
NEONRT98's Avatar
NEONRT98
55 is end of codes...
Old Aug 12, 2006 | 11:00 AM
tomthedog's Avatar
tomthedog
oops...good catch. any codes yet?
Old Aug 12, 2006 | 08:54 PM
mmench's Avatar
mmench
i couldnt check. i lost my stupid keys at work and my only spare is three hours away at my moms house but i should have it in a day or two so i can check. i was so mad
Old Aug 19, 2006 | 05:29 PM
mmench's Avatar
mmench
the codes are 12, 23, and 37
Old Aug 19, 2006 | 07:37 PM
das2123's Avatar
das2123
23 Intake air temp sensor out of range
37 Torque converter clutch solenoid CKT or park/neutral switch failure
Old Aug 20, 2006 | 03:29 PM
mmench's Avatar
mmench
i know that i had the tranny turque converter code. because it wont go away even if we delete it. but i dont have an air intake temp sensor. i think the previous owner took it out cuz the just a plug in its place.
