ok heres the deal. i let my car (it a project car) sit for two weeks. wen i went back it barely ran and i had to peddle the gas to make it run. it also wont rev past about 3500 rpms, when it gets that high it feels like a rev limiter.. i fooled with the cam sensor and it ran normal again, my friend pulled the throttle body open and it ran till red line. but only for a few seconds. so i replace the sensor and still have the same proble. any ideas on what to do. PLEASE HELP!
the timing is fine . i have a fiend with the scanner tool that i am getting on saturday. but i bet it is making codes cuz when i reset the computer it worked fine. but only for a sec or two. thanks for input
you have to do this with in 5 sec of putting the key in. turn key to "on"-right before start, "off"-one click back, on, off, on. wait and the light WILL flash. FLASH pause FLASH..FLASH is code 12, batt discon in last 50 starts. 50 is end of codes. it's almost 11pm where i live, get crack'N.
i cant do it till tomorow cuz i at work now and dont get off till eleven but i will update u when i do it. im on the east coast so i still got a while till i get off too.
