back seat covers..
Old Aug 9, 2006 | 10:07 PM
PurePower69's Avatar
PurePower69
Default back seat covers..
How would i remove the back seat covers in my neon? I can do the fronts however the back bench seat is giving me trouble. I wanna out these in.... http://cgi.ebay.com/ebaymotors/95-96...QQcmdZViewItem
Old Aug 9, 2006 | 10:32 PM
das2123's Avatar
das2123
Default RE: back seat covers..
The bottom seat just pops out. Just pull on it, it's held in by 2 clips. The other part has two torx screws that can be pretty tough to get out. Try using some PB Blaster and a breaker bar to get the out.
Old Aug 10, 2006 | 12:02 AM
spudsterier's Avatar
spudsterier
if you are wanting to completely remove the covers:
....when you get the back frame out, there are two bolts, one on each side of the frame (13mm) that are inset into the frame...you have to remove the staple on the zipper and then unzip the cover on the frame....after you loosen them, the coushins will fall right out...then you lift up the little overhang flap that is on the bottom of the coushin....there should be 2 little plastic plugs on there too wolding the flap down...under the flap the is a long plastic connecting rail, use a screwdriver to pry them apart....then pull of the cover...
as for the bottom (butt) coushin....under the coushin there are little snap rings you can either twist them around to get them out or cut them off....they are kinda shaped like a loop-d-loop....then you can go to a parts store and order more...i recommend cutting them, its alot easier....then the cover just comes off...but beware there will be a few more about in the middle of the coushin where the crease line is ontop....
