Misfire after 3000rpm
Old Aug 16, 2006 | 01:30 AM
HabitatHxC's Avatar
HabitatHxC
Default Misfire after 3000rpm
Ok my buddies neon has a misfire after 3000rpm, weve checked timing, we checked fuel, we checked spark. What could cause the misfire?
Old Aug 16, 2006 | 03:24 AM
NEONRT98's Avatar
NEONRT98
Default RE: Misfire after 3000rpm
Replace the spark plugs
Old Aug 16, 2006 | 07:10 AM
HabitatHxC's Avatar
HabitatHxC
we have spark. time, and fuel.
Old Aug 16, 2006 | 02:50 PM
NEONRT98's Avatar
NEONRT98
You might have all three of those, but it doesnt sound like the spark is sufficient enough ;-) What kind of plugs are you using? I bet that if you change the plugs it will clear up.. My neon did it once when I accidently cleaned one plug with brake cleaner.. it would misfire under hard accelleration.. Its cheap to change plugs, start there..
