camshaft
Old Aug 22, 2006 | 06:32 PM
95neonriceeater's Avatar
95neonriceeater
Default camshaft
i was reading on the internet that the stock 1995 neon's camshaft was changed in 96 and is now offered as a mopar performance part
does this mean that since my cam is bigger that i have more power than 132hp?
Old Aug 22, 2006 | 06:45 PM
das2123's Avatar
das2123
Default RE: camshaft
It's a more aggresive cam...
95:Intake valve lift - 7.8 mm, centerline - 108 degrees, overlap volume - 2987 mm3.
96-99:Intake valve lift - 7.2 mm, centerline - 113 degrees, overlap volume - 2039 mm3.
According to the Mopar catalog it's worth 4HP over the 96-99 cams.
Old Aug 22, 2006 | 06:46 PM
95neonriceeater
so i have around 138hp?
Old Aug 22, 2006 | 06:55 PM
das2123's Avatar
das2123
ORIGINAL: 95neonriceeater
Probably, but be careful with the "rice" math.
The magnum cam is even more agressive...
01 SOHC Magnum's have 8.75mm intake lift and the 02-04 Magnum's have 8.50mm lift. Thats what I have in my 97 SOHC
Old Aug 22, 2006 | 06:58 PM
95neonriceeater
hahah
which one do you have?
i probably won't change it any time now
but in the future
Old Aug 22, 2006 | 07:04 PM
das2123's Avatar
das2123
02-04 magnum cam
i probably won't change it any time now...but in the future
Change it to a magnum cam?
Old Aug 22, 2006 | 07:06 PM
95neonriceeater
yea
why didn't you get the 8.75?
Old Aug 22, 2006 | 07:07 PM
das2123's Avatar
das2123
The guy didnt have a 01 neon!
Old Aug 22, 2006 | 07:11 PM
95neonriceeater
what about an 01 neon?
i thought the 8.75 was from the magnum
Old Aug 22, 2006 | 07:14 PM
das2123's Avatar
das2123
