kyb gr2
Old Sep 3, 2006 | 03:19 PM
hndawht's Avatar
hndawht
Default kyb gr2
hey i brought my car in finally to get a 4 wheel alignment after i did my struts and they told me that my rf strut is bent its out by -1.2 im wondering if i possibly didnt get the spring back on properly or if they have any adjustments, i dint rember seeing any though, or do u think i should just order in a new strut, i thikn if its the strut though im just gonna say forget it and order the coilovers and give my lil bro 3 good struts for his neon
Old Sep 3, 2006 | 04:37 PM
spudsterier's Avatar
spudsterier
Default RE: kyb gr2
when putting the spring back on the strut you cant get it too far off....but the mount, if you dont rotate the mount untill it ligns up completely then it will bend it a little......i had this problem with my konis.....it was to the point where if i left the top mounted to the car and removed the bottom of the strut off the spindle, it would sit about 3 inches forward from where it should...dont know if this helps but there it is
