Shift Cable bushings
Old Sep 7, 2006 | 10:03 PM
meredithscaulk's Avatar
meredithscaulk
Default Shift Cable bushings
Is there anything i can use to replace the shift cable bushings in my engine compartment? They are gone, and every shop i go to saysthat they are not made?
Any ideas or suggestions?
Old Sep 7, 2006 | 10:36 PM
rrwertz's Avatar
rrwertz
Default RE: Shift Cable bushings
www.boogerracing.com
Old Sep 7, 2006 | 11:13 PM
das2123's Avatar
das2123
ORIGINAL: rrwertz
Thats them...and they are great. They take some getting used to, but worth it.
Old Sep 7, 2006 | 11:49 PM
meredithscaulk
Will adding these help save, or at least delay needing to change, my shift cables? I am having my clutch replaced, and my mechanic said i needed new cables. I am hoping the bushings will save them.
Old Sep 8, 2006 | 12:27 AM
das2123's Avatar
das2123
Probably...most people say it's the cables, but it's usually the bushings.
Old Sep 8, 2006 | 01:00 AM
ewetho's Avatar
ewetho
Those missing bushings are what is removed to install BoogerBushings. So unless you cable is physically damaged another way that is all you need.
Old Sep 8, 2006 | 01:05 AM
spudsterier's Avatar
spudsterier
he is probally just saying that you need new cables because unless you get the booger bushings, the only way to get new ones is to replace the whole cable assembly
Old Sep 8, 2006 | 02:05 PM
lblackneon's Avatar
lblackneon
The booger bushings also improve the feel of the shifter. The booger bushings were one of the first things I put on. I recently received my STS with more booger bushings to go along with it just incase.. U can't go wrong with them. Howell automotive and Modern performance have them too.
Old Sep 8, 2006 | 02:08 PM
das2123's Avatar
das2123
They are a bit cheaper direct from Jeff though.
Old Sep 8, 2006 | 03:00 PM
meredithscaulk
Thanks. i'll be ordering them tonight. Does he have a pretty quick turn around on shipping?
My mechanic wants his email. he replaces at least a set of cables on Chrysler cars a week because of bushings.
