ATX to MTX I'm New :(
Old Sep 11, 2006 | 04:02 PM
ZiggyNeon's Avatar
ZiggyNeon
Default RE: ATX to MTX I'm New :(
i found a 1995 that needs valve work
guy wants 500 for it i can talk him down prolly
if i bought that would the tranny still be good an all u think?
i would still need to buy a clutch fly wheel and t/o bearing though right
Old Sep 11, 2006 | 04:09 PM
dogdaysunrise's Avatar
dogdaysunrise
i would go for it
check the millage of the donor car, if its below 250 thou, then i would say its still good.
Old Sep 11, 2006 | 05:12 PM
das2123's Avatar
das2123
ORIGINAL: spudsterier
just a thought here.....
why would the r/t's be better for highway mailage if the 5th gear revs higher????
the sohc trans i once had in my old car gave me alot better gas milage then the r/t trans did...5th gear on the sohc trans runs about 500rpms lower then the dohc trans does
Other way around is what I meant. The 0.72 fifth gear would be the better one for gas milage.
ORIGINAL: ZiggyNeon
Tranny should be OK and yes you should get a new t/o bearing.
Old Sep 11, 2006 | 05:17 PM
ZiggyNeon's Avatar
ZiggyNeon
just a new t/o bearing ?
Old Sep 11, 2006 | 05:20 PM
ZiggyNeon's Avatar
ZiggyNeon
ORIGINAL: racerx55
i boguht the whole shot, CV shafts, clutch, flywheel, evrything from a junk yard for $500, it all came out of a 98 r/t, except i didnt get the PCM, im still running the automatic PCM in mine, i hooked the neutral safety switch wire to the pedal switch and grounded the other side so it start only with the clutch in and has a 6750 rev limit when the clutch it out, when you bang gears it kills the motor for you when you hit the clutch if its above 5500, only problem i have with that is the idle speed goes up or down if the pedal is in or out
what do you mean when i "bang" gears new to mtx's
Old Sep 11, 2006 | 05:23 PM
das2123's Avatar
das2123
ORIGINAL: ZiggyNeon
If the car has alot of miles on it, then I'd get a new clutch as well.
Old Sep 11, 2006 | 05:33 PM
ZiggyNeon's Avatar
ZiggyNeon
kinda off topic here now
would it be easier to swap the motors ? like put the new motor in the mtx neon im going to buy?
Old Sep 11, 2006 | 05:48 PM
das2123's Avatar
das2123
ORIGINAL: ZiggyNeon
I'd rather swap trannies. Besides you have a 98 and they are different from the 95...some sensors are different. And it depends what you consider easy...either way you have to pull the engine and tranny.
Old Sep 11, 2006 | 06:09 PM
ZiggyNeon's Avatar
ZiggyNeon
true very true totally forgot it was a different year lol
i'm just hoping this guy still has the neon for sale lol
itll be cheaper for me to buy the donor car keep it in the garage a couple weeks
get a new flywheel, clutch, and t/o bearing
that brings me to another question
can anyone tell me what flywheel , clutch and t/o bearing to get
tihs cars gonna be a daily driver i just wanna get more whp and torque so its more "fun" to drive it
so if anyone (das) can guide me to a clutch flywheel and t/o bearing id aprreciate it
like would this work or be any good ?? ::: clutch flywheel t/o bearing on ebay "any good?"
Old Sep 11, 2006 | 06:25 PM
das2123's Avatar
das2123
T/O or Release Bearing
Sachs - Clutch Kit or the PT Clutch is good also.
Not sure about the flywheel...how much are you wanting to spend?
