What's causing this loose shifter, loose front to back
Old Sep 12, 2006 | 10:00 PM
bcuzau's Avatar
bcuzau
Default What's causing this loose shifter, loose front to back
Hi,
Can someone tell me what's wrong. The shift stick is slack front to back, in nuatral and in all gears.. it does shift into gears, at the very end of the throw. I drove it home fine fom work, but it hasn't been driven since. the cable seems fine at this end, i mean the cable just moves in/out of the sleeve as much as the shifter moves. Is it adjustable?
here's what it loks like, vid
Old Sep 12, 2006 | 11:18 PM
das2123's Avatar
das2123
Default RE: What's causing this loose shifter, loose front to back
Bushings have crapped out...get some Boogers from http://www.boogerracing.com/indexbb.html
Old Sep 13, 2006 | 12:30 AM
NEONRT98's Avatar
NEONRT98
More specifically, its the bushings where the cables meet the transmission.
Old Sep 13, 2006 | 02:10 AM
das2123's Avatar
das2123
ORIGINAL: NEONRT98
Thank you for making that more clear
