dohc head on a sohc block?
Old Sep 12, 2006 | 11:51 PM
duelsxt's Avatar
duelsxt
Default dohc head on a sohc block?
Will this work. Put a dohc head on a sohc block? If so what do I have to change?
Old Sep 13, 2006 | 01:27 AM
neoncrazy101's Avatar
neoncrazy101
Default RE: dohc head on a sohc block?
its possible their the same blocks...not sure of everything you'll have to change though...
Old Sep 13, 2006 | 01:38 AM
spudsterier's Avatar
spudsterier
intake manifold
exhaust manifold
timing belt
thermostat housing(if the manifold doesnt come with it)
passenger motor mount bracket
timing belt cover(front and rear)
cam sensor
pistons/rods
should be it...unless you dont wanna modify the hood...then you need one of them too
Old Sep 13, 2006 | 02:14 AM
das2123's Avatar
das2123
You don't have to change the pistons, but it's a good idea.
Old Sep 13, 2006 | 02:52 AM
DNeon's Avatar
DNeon
ORIGINAL: das2123
I thought you did? doesnt the DOHC pistons have valve grooves in it? Isnt that important?
Old Sep 13, 2006 | 03:06 AM
spudsterier
DOHC pistons do have the little seats in it, so i thought they did too.
Old Sep 13, 2006 | 12:11 PM
das2123's Avatar
das2123
Nope, you will just have lower compression.
Thats why some people will put a DOHC head on their SOHC and then put an SRT-4 turbo on. No adapter plate and then you can also port and polish the intake manifold. Plus the DOHC head flows much better than the SOHC. The DOHC pistons would make a noticable difference as well, but again not necessary.
