fuel pump ?
fuel pump ?
my fuel pump is not turning on for some reason, I first though it was my fuel pump so I picked up another one and it still does not turn on, so I took the original one that I thought had gone bad and tried it on the battery and it turns fine. any ideas?
I tried changing the relay with the stasrter one.. cause I know that one works and nothing, the fuse is also fine
The engine is not giving me any error codes.. could it be a sensor?
Thanks in advance
Danny.
Thanks in advance
Danny.
RE: fuel pump ?
turns out that it's not my fuel pump at all, it's actually my ignition fuse that burns out, I tried a 20 amp fuse and it burnt, so I tried a 25 amp fuse and its worked fine, but I'm suposed to only use a 10 amp fuse
The weird thing is after I change the 10 amp fuse I get to drive like a kilometer or so before the fuse burns out.
but like i was saying with the 25 amp fuse it's working fine
So now I'm wondering what could be burning up my ignition fuse?
Danny.
Danny.
