FU#*^ING CAM!!
Old Sep 18, 2006 | 12:00 AM
1994shadowman's Avatar
1994shadowman
Default FU#*^ING CAM!!
I feel so bad for my bro's neon. It wasnt running right and was a throwing Code 11. (that the crankshaft wasnt in time with the cam). It turns out one of the cam pins that attaches the cam to the gear broke off and threw the code. now he has to get the thing fixed and have the cam pushed on the gear at Chrysler for $600. [:@] Just a rant.
Old Sep 18, 2006 | 12:31 AM
racerx55's Avatar
racerx55
Default RE: FU#*^ING CAM!!
by a new cam its cheaper
Old Sep 18, 2006 | 12:51 AM
HabitatHxC's Avatar
HabitatHxC
I have 2 sohx cams for a neon, if you have a 96+ it ill add like 3 hp, Soooo Let me know if you want it.
Old Sep 18, 2006 | 02:15 AM
das2123's Avatar
das2123
ORIGINAL: HabitatHxC
Are they from a 95?
Old Sep 18, 2006 | 02:32 PM
ZiggyNeon's Avatar
ZiggyNeon
ok this brings up a question das...ive got a 2.5 catback coming wed and thinking about getting the pacesetter header what cams should i aim for
Old Sep 18, 2006 | 02:57 PM
das2123's Avatar
das2123
Go with the Crane #12 cam and don't forget about the springs and retainers...they will have to be upgraded as well. If you are on a budget, you can go with a 95 cam or a magnum cam with magnum springs and retainers.
Old Sep 18, 2006 | 03:13 PM
ZiggyNeon's Avatar
ZiggyNeon
yeah im definately on a budget lol so any cheap quick upgrades are definatley for me
Old Sep 18, 2006 | 03:20 PM
das2123's Avatar
das2123
ORIGINAL: ZiggyNeon
I'd try to get them in this order then: 2001 Magnum cam, 02-04 Magnum cam and then the 95 cam. The Magnum cams are from the 2nd gen R/T's and ACR's.
Old Sep 18, 2006 | 07:48 PM
ZiggyNeon's Avatar
ZiggyNeon
ORIGINAL: das2123
[I'd try to get them in this order then: 2001 Magnum cam, 02-04 Magnum cam and then the 95 cam. The Magnum cams are from the 2nd gen R/T's and ACR's.
so all of those will just fit right in i wont have to do any mods?
Old Sep 18, 2006 | 07:52 PM
das2123's Avatar
das2123
ORIGINAL: ZiggyNeon
ORIGINAL: das2123
They all fit. If you go with the Magnum cam you will need the lifters and springs also. If you go with the 95 then all you do is swap it in.
