push in clutch...hear air..
Old Sep 18, 2006 | 04:09 PM
neoncrazy101's Avatar
neoncrazy101
Default push in clutch...hear air..
i went out to my car today to go to school...and i pressed in the clutch pedal...and i could hear air or something coming out... i dont know where and it did it till i got to school... the clutch still felt the same and everything...u just had that sound whenever it was pressed in... but then when i got in my car to go back home (about an 2 hours later) the sound was gone... could this be related to the master cyl. for the clutch?
Old Sep 18, 2006 | 04:20 PM
dogdaysunrise's Avatar
dogdaysunrise
Default RE: push in clutch...hear air..
the clutch on a neon is a cable not hydraulic. The sound you are hearing could just be from the friction of the clutch.
Old Sep 18, 2006 | 04:29 PM
neoncrazy101
ok good...thats a relief lol...
Old Sep 18, 2006 | 05:22 PM
das2123's Avatar
das2123
ORIGINAL: dogdaysunrise
The 95-00 are cable...01 + are hydraulic. Just a little FYI.
Old Sep 19, 2006 | 04:17 AM
dogdaysunrise
ORIGINAL: das2123
[/quote]
good to know. that could make for an intresting swap.
Old Sep 19, 2006 | 04:29 AM
racerx55's Avatar
racerx55
it could be the throwout bearing starting to wear & make noise, ive heard some noisy when theyre cold and get quieter as it warms up, if its not really loud i wouldnt worry too much till it gets worse
Old Sep 19, 2006 | 11:34 AM
das2123's Avatar
das2123
ORIGINAL: das2123
[/quote]You can use the hydraulic tranny as long as you change the bellhousing as well.
