Bad Squeal
Old Sep 18, 2006 | 08:45 PM
Russty's Avatar
Russty
Default Bad Squeal
My 96' 4 dr Dodge Neon is running fine. The only complaint that I have is The Belt squeals very badly. It always squeals when I start it and It will do it every now and then when im driving . Some days are better than others sometimes it will only squeal when i start it but most of the time it squeals a lot and it is verey loud and embarasing. What can I do to fix it.
Old Sep 18, 2006 | 08:52 PM
NeonGT's Avatar
NeonGT
Default RE: Bad Squeal
it your alt. belt. there is a bolt on the passnger side and on back loosen the passnger on then tightn the back on then check the belt to see how tight it is once u get it where u want it tightn the passnger side bolt. hope that help u.
