trans leak
Old Sep 19, 2006 | 02:02 AM
spudsterier's Avatar
spudsterier
Default trans leak
well i finally got the wifes car back together, now there is a horrible leak. it ran real good and didnt leak anything for a while, but as soon as i put it in gear trans fluid started pouring out the hole that the CV joint goes in. after most of the fluid ran out, then it just had a constant drip. within about 10 minuites about 3 quarts drained out. now it sux because we cant trade it in tomorrow...unless i figure it out before hand
i guess it might be a seal in there
Old Sep 19, 2006 | 02:20 AM
rrwertz's Avatar
rrwertz
Default RE: trans leak
there is an axle seal. mine started leaking for no apparent reason. I bought an axle seal puller to get the old one out. don't nick up the aluminum or it'll be leaking again...
Old Sep 19, 2006 | 10:19 AM
spudsterier
where can i get an axel seal and how much????
i was checking autozone on the i-net and it says they dont have any......
Old Sep 19, 2006 | 02:59 PM
dogdaysunrise's Avatar
dogdaysunrise
only place i have ever been able to get one is at the stealership. you might luck out and find them at a trans shop.
Old Sep 19, 2006 | 07:39 PM
spudsterier
well nevermind....i feel like a dumb ***......the shaft just wasnt locked in all the way....[:-]
Old Oct 21, 2006 | 11:40 AM
press1280's Avatar
press1280
It looks like I have the same deal as you, but I was able to get the part from Advance Auto Parts for only a few bucks(I'm not sure if I got the right thing now). It's a metallic ring that is colored red(the one currently on the car is blue).The size of the seals appears the same though.I haven't taken the axle off yet.Is there another seal I may be missing? The trans fluid drips right below the seal.
Old Oct 21, 2006 | 02:54 PM
spudsterier
i ended up finding out that since i was in a huury putting the car back together, i didnt lock the shafts into the trans al the way....i was getting real frustrated and must of just thought they went it............but the car has long since been gone and traded it
hope your problem gets fixed easily
