Gauge cluster already soldered
Old Sep 19, 2006 | 05:24 PM
ZiggyNeon's Avatar
ZiggyNeon
Default Gauge cluster already soldered
ok ive known about the re flowing the solder'd points on the circuit board but what if youve done that and 2-3 weeks later your speedometer is acting up again...is it the VSS(Vehicle Speed Sensor)??
Old Sep 20, 2006 | 12:07 PM
das2123's Avatar
das2123
Default RE: Gauge cluster already soldered
Does your odometer still work? If not, then it's probably your VSS. If it does, try resoldering again and adding a bit of solder. If that doesn't work, you may just need a new one.
Old Sep 20, 2006 | 01:48 PM
ZiggyNeon's Avatar
ZiggyNeon
yeah odometer and trip-o-meter still works its just the speedometer that drops every now an then
Old Sep 20, 2006 | 01:50 PM
das2123's Avatar
das2123
Then you can try the soldering again and making sure the connections on the back are secure or get you a new one.
Old Sep 20, 2006 | 02:00 PM
ZiggyNeon's Avatar
ZiggyNeon
i think its just the connections them selves...seeing how if i push on the bottom of the cluster in the middle the speedo comes back on
Old Sep 20, 2006 | 02:03 PM
das2123's Avatar
das2123
The pins aren't making a good connection then.
Old Sep 20, 2006 | 02:10 PM
ZiggyNeon's Avatar
ZiggyNeon
what i figured so i just punched it in there pretty good and tightened really tight heh hopefully that works
Old Sep 20, 2006 | 07:25 PM
ZiggyNeon's Avatar
ZiggyNeon
yeah that didnt work its still acting up so im thinking for an easy fix ima just get an a pillar gauge bezel and then get an aftermarket speedo
Old Sep 21, 2006 | 07:40 AM
racerx55's Avatar
racerx55
wow when mine acted up the speedo quit, odometer and trip quit, and the tach would quit randomly, the speedo would jump around over bumps, charge light and ABS light would flicker on bumps,and sometimes i'd see the low fuel light flicker on & of with the charge light - i resoldered the connections and it works like new again
Old Sep 22, 2006 | 05:31 AM
dirtysohc79's Avatar
dirtysohc79
I just bent them with a flathead screwdriver and havent had any problems since.
