Which should I do?
Old 09-26-2006, 08:48 PM
95neonriceeater's Avatar
95neonriceeater
95neonriceeater is offline
Default RE: Which should I do?
magnum intake what?!?!?!?!?!?!?!?!?!?!?
and how much are thoughs?!
along witht he 01 ram cam
hahah
  #42
das2123's Avatar
das2123
das2123 is offline
ORIGINAL: 95neonriceeater
should i do that das?
Do what? You can't polish the plastic intake...its already smooth, but you can port match it
how much are they usually at junkyards?! and does it matter if its atx or mtx?
About $30-$60 depending on the yard and no, tranny doesn't matter.
Since you have a SOHC, look into the Magnum Intake swap. This will be a step for me somewhere down the line.
  #43
Old 09-26-2006, 08:49 PM
95neonriceeater
what year and how much?
if it's cheap im gonna get it so when i put the new head gasket on i just swap them
  #44
Old 09-26-2006, 08:56 PM
das2123's Avatar
das2123
das2123 is offline
All second gen R/T's and ACR's came with the Magnum engine. They run about $175-$250.
There is a little more to the swap.
  #45
Old 09-26-2006, 11:12 PM
spudsterier's Avatar
spudsterier
spudsterier is offline
oh i was kinda in a hurry writing that...i meant third...i fixed it now
  #46
Old 09-26-2006, 11:48 PM
jkgoff2007's Avatar
jkgoff2007
jkgoff2007 is offline
would i be better off to get a udp or the header?
  #47
Old 09-27-2006, 12:30 AM
das2123's Avatar
das2123
das2123 is offline
ORIGINAL: jkgoff2007
Header adds HP, a UDP frees up HP. What do you want? Honestly, I'd go with the header.
  #48
Old 09-27-2006, 01:04 AM
jkgoff2007's Avatar
jkgoff2007
Which one would help more in a race?
  #49
Old 09-27-2006, 01:08 AM
das2123's Avatar
das2123
das2123 is offline
What kind of race?? From a stop or roll and for how long? The UDP will help more from a stop and the header would be better for a longer race seeing as it would help more in the top end.
  #50
Old 09-27-2006, 01:12 AM
95neonriceeater
is it better to get the modern performance udp since it comes with the belt?
or just one off ebay
