Catalytic Converter Question
Old Sep 24, 2006 | 01:19 AM
KGT's Avatar
KGT
Default Catalytic Converter Question
Hey guys, I don't know cars well so hang with me. I have a 96 Neon that recently failed a smog test. After the diagnostic the mechanic said that I need a new catalytic converter. He said something about it being computerized and only the dealership has the cat--and that is would cost $515.00. I was skeptical, and talked to my friend about it (who does know cars very well). My friend said that I could get one at an auto-parts store for about $100.00, and installation would cost about $60. Would you guys say this is accurate? And what type of catalytic converter do I get for a 96 Dodge Neon?
Old Sep 24, 2006 | 01:35 AM
spudsterier's Avatar
spudsterier
Default RE: Catalytic Converter Question
just get a stock replacement....the second price would sound about right....but not the first
Old Sep 24, 2006 | 02:58 AM
das2123's Avatar
das2123
A Magnaflow Cat Converter from Modern runs $65.
Install it yourself (very easy) and then have someone weld it on for about $20.
Old Sep 24, 2006 | 03:16 AM
neoncrazy101's Avatar
neoncrazy101
i found a magnaflow Cat. on ebay for 50...uncluding shipping
Old Sep 24, 2006 | 09:09 AM
racerx55's Avatar
racerx55
them smog check guys dont know their *** from a hole in the ground.... they did away with smog check here cuz brand new cars werent passing it by a long shot
Old Sep 24, 2006 | 09:11 AM
racerx55's Avatar
racerx55
speaking of cats.. does one run crappy without a cat on it? i still have both o2 sensors in, just the cat has been replaced with pipe
could that be why it seems to be slackin so bad?
Old Sep 24, 2006 | 09:34 AM
neoncrazy101
well i heard in this forum about post 95's the downward sensor talks with the PCM bout the mixture so if thats true then most likely it could be causing it to slack.
Old Sep 24, 2006 | 10:14 AM
racerx55's Avatar
racerx55
sucks before i got this car i threw away a complete new exhaust system off one , well for what it cost for a magnaflow it might be worth a shot, we dont have any sort of inspection or smog check around here so i never bother with stuff like that very often
Old Sep 24, 2006 | 10:59 AM
spudsterier
i had a pacesetter header, no cat, 2.5in. pipe, and a fart muffler on my last r/t and it ran great......it was just very loud
Old Sep 24, 2006 | 11:58 AM
racerx55's Avatar
racerx55
i found the problem with it slackin off, 28 psi fuel pressure, im surprised it even runs, lol - time for a new pump
