A couple questions
Old Oct 5, 2006 | 10:42 PM
Chris2121's Avatar
Chris2121
Default A couple questions
I just bought an engine from the junkyard. I appears to have a mls hg, and seems to be in good shape. The timing belt looks brand new, but im not sure. It is a goodyear gatorback belt, and i would like to know if i need to replace it, i would rather spend the $50 on something else. It still has writing on the belt, and their are no cracks or fryed ends whats-so-ever. Should i replace it or not. Also i need new belts, are duralast ok, i have valuecraft, but they look cheap so im going to return them.
Old Oct 5, 2006 | 11:14 PM
pimpberetta's Avatar
pimpberetta
Default RE: A couple questions
Do the belt tensioner, belt, and water pump. You will thank yourself in the long run. Trust me.
A blow up engine is more costly then a little preventative maintanence.
Old Oct 6, 2006 | 12:21 AM
spudsterier's Avatar
spudsterier
better safe then sorry....there are alot of options on what accessory belts to use.....but, most of them are basically the same. i have cheap off brand ones from farm and fleet on mine and they havent given me any problems.
Old Oct 6, 2006 | 01:47 AM
das2123's Avatar
das2123
Gatorback belts are REAL quality belts. I'd probably change the timing belt, water pump, and tensioner pulley just to be safe.
