Suspension? 1999 Neon
Old Oct 6, 2006 | 07:22 PM
dege@usa.com's Avatar
dege@usa.com
Default Suspension? 1999 Neon
I am getting a clunking out of the front while driving. When I go very slow I don't get it or don't notice it, and when I accellerate it disappears until I let off the gas and then it can get very loud and disturbing. Usually I can find a speed around 55 to 60 where it is virtually unnoticealbe but as soon as I start to slow down, it comes back on strong. Any one have any thoughts? Suggestions?
Thanks much for your input.
Old Oct 6, 2006 | 08:16 PM
das2123's Avatar
das2123
Default RE: Suspension? 1999 Neon
I would take a look at the struts and strut mounts first.
Old Oct 7, 2006 | 04:47 AM
racerx55's Avatar
racerx55
strut bushings,control arm bushings, ball joints, tie rod ends will quit making noises under acceleration or braking
Old Oct 7, 2006 | 04:56 PM
racerx55's Avatar
racerx55
and a loose brake caliper will make all kinds of rattling untill you hit the brakes..
Old Oct 9, 2006 | 03:24 AM
Newneonguy's Avatar
Newneonguy
one time my wheel was clunking after having it worked on and it turned out that they didnt tighten the lugs good enough...scary.
Old Oct 10, 2006 | 06:08 PM
dege@usa.com
It was a tie rod end! Thanks Much all!
