light in headliner not working, how do I fix it?
Old Oct 7, 2006 | 01:20 AM
neonstatus's Avatar
neonstatus
Default light in headliner not working, how do I fix it?
Hello, I tried the search engine and couldn't really find anything that would help me. Ok, here is the problem: The light in the headliner does not work at all, and I have tried new bulbs and checked the fuse. Any suggestions on fixing the problem? I will not bring it to a dealership to get it checked, waste of money. TIA!
Old Oct 7, 2006 | 01:57 AM
neoncrazy101's Avatar
neoncrazy101
Default RE: light in headliner not working, how do I fix it?
Could be a wire broken somewhere. it doesn't even work if u turn it on manualy via headlight switch?
Old Oct 7, 2006 | 02:12 AM
spudsterier's Avatar
spudsterier
if you have to trace the wires, they are glued to the top of the headliner, then run down the rear quarter panel, then into a plug by the top driverside corner of the back seat...then they run down to the floor and along the edge of the floor into a wire harness by the lip under the rear seat and then up to the dash
Old Oct 7, 2006 | 02:23 AM
neoncrazy101
take it u traced them before Spud? lol
Old Oct 7, 2006 | 10:14 AM
spudsterier
a few times, but ive also stripped out alot of neons in past years.....i think about a dozen
Old Oct 7, 2006 | 03:12 PM
pimpberetta's Avatar
pimpberetta
There is a fuse under the hood for interior light. Try that, mine went out probably from playing under the dash too much with the battery connected lol
Old Oct 7, 2006 | 08:02 PM
neonstatus's Avatar
neonstatus
Thanks Spud, I will be taking out the headliner and other nes. parts to figre out whats wrong with the wire. Have you ever seen people who have redone their headliner in a new material? I probably will end up doing mine over since I will have it out, but I am not sure what material to use. I dont want it to look crazy so it wont be any strange colors or anything.. lol
Beretta, I already checked the fuse.
Old Oct 7, 2006 | 11:19 PM
ZiggyNeon's Avatar
ZiggyNeon
ORIGINAL: neoncrazy101
but like neoncrazy said can u turn it on manually. if you can then its just ur pin switch for your door has a bad ground prolly what mine was doing would go on with all the other doors but the driver one lol so i just unscrewed it then put it back in and it works fine
Old Oct 7, 2006 | 11:32 PM
spudsterier
its easy to redo the headliner in a different material.....i have my old headliner sitting in my basement that i redid in kinda like a blue velvet type of material....thats the one thing i didnt have a picture of in the car.....
