timing
Old Oct 7, 2006 | 11:30 PM
96dodgeboy's Avatar
96dodgeboy
Default timing
How would you know if you`ve jumped 1 or more teeth on belt without taking cover off
Old Oct 7, 2006 | 11:36 PM
spudsterier's Avatar
spudsterier
Default RE: timing
is it a dohc or single????
if its a single then im not sure how to check...
but if its a dual then you remove the inspection cover in the middle of the timing cover....then you rotate the engine til you see the two notches on the edge of the cam gears, they should line up in a horizontal line......then remove the #1 sparkplug and stick a wooden dowl rod into the sparkplug hole and rotate the engine slightly until the dowl rod is at its highest point(top dead center)....then check the cam marks again
Old Oct 7, 2006 | 11:40 PM
96dodgeboy's Avatar
96dodgeboy
Default RE: timing
sorry, its a 99 2.0 sohc
Old Oct 8, 2006 | 12:02 AM
racerx55's Avatar
racerx55
Default RE: timing
you normally get code 11 from the ECM
maybe not on a 99, i think they have the P codes...
Old Oct 10, 2006 | 12:45 AM
rrwertz's Avatar
rrwertz
Default RE: timing
if your timing is off 1 tooth, the car most likely will not start or will run like crap. that's the easiest way to know...
should throw a code 11 like racerx said.
Old Oct 10, 2006 | 01:03 AM
spudsterier
Default RE: timing
if you have to hold the gas to the floor when turning it over then thats a good sign that the timing is off
