lowering
Old Oct 8, 2006 | 02:47 PM
jakedlee16's Avatar
jakedlee16
Default lowering
hey my freind is selling his lowering springs to me but they are from a 2000 will they fit on my 95 its just the springs so...i dont see where this would be a problem but i was wondering if 45 bux is too much ..i have no clue what cmpany they are theyre yellow and they drop 2/3 so...if anyone has any info or feedback about my question def. let me know im buying them next friday unless you guys say otherwise
Old Oct 8, 2006 | 05:38 PM
HabitatHxC's Avatar
HabitatHxC
Default RE: lowering
Ive heard they will fit, but there will be some wiggle when you jack the car up (like the spring will be loose) but other than that i think they will work.
Old Oct 8, 2006 | 05:55 PM
spudsterier's Avatar
spudsterier
there should only be some wiggle if the springs have been cut to lower it more.....if the springs have been cut then dont waste the money....even 45 bucks..
if they drop the car 2/3 then its gonna drop your car a little more then an inch.....
if they are yellow then most likely they are Gold Line springs....but gold lines are a 2 inch drop
Old Oct 8, 2006 | 07:10 PM
jakedlee16's Avatar
jakedlee16
yeh..we kinda guesstimated the 2/3 drop but there not cut there still good to go so ur probly right about being goldline but are they a good quality spring and are they worth 45$?
Old Oct 8, 2006 | 08:39 PM
95neonriceeater's Avatar
95neonriceeater
eibach/mopar springs are $200
do the math buddy
Old Oct 8, 2006 | 10:56 PM
dj_mars's Avatar
dj_mars
those are good springs $45 for the 4?? is so thats a great deal jump on that **** i would if i needed springs... depending on the series tire u have they could rub
Old Oct 9, 2006 | 12:05 PM
das2123's Avatar
das2123
They might not drop the 1st gen as much as the 2nd gen though. Remember, 2nd gens are a bit taller, that's why they can put 1st gen springs on there to lower their car.
Old Oct 9, 2006 | 12:10 PM
racindirt35's Avatar
racindirt35
Go on ebay and find lowering springs for a Dodge Neon... I got some on the car I bought and it makes the ride rough espically when i hit a bump. Also if you do put lowering springs on it u will bottom out. I did and it ripped my front end to peices.
Old Oct 9, 2006 | 02:08 PM
racerx55's Avatar
racerx55
hate when that happens.. lol
[IMG]local://upfiles/37714/6B011D2DD92841A59544E2D8C25F03E3.jpg[/IMG]
[IMG]local://upfiles/37714/725286278F35419A8CB7F2ED0D6ED4EF.jpg[/IMG]
Old Oct 9, 2006 | 04:08 PM
spudsterier
all depends on how low you drop the car.....a 1 inch drop wont bottom out the car or mess anything up.....neither will a 2 inch drop...any more will start messing things up
