Calling all help.....
Old Oct 14, 2006 | 01:17 AM
LivinNstiX's Avatar
LivinNstiX
Default RE: Calling all help.....
it could be the cam seal but when i had those problems it ended up being the head gasket...
it ran down the back of the block and down off the filter, hell change'em both why your at it
Old Oct 14, 2006 | 01:35 AM
pimpberetta's Avatar
pimpberetta
Well like I said, I can see the oil even through the peep hole in the timing over spewing out. If it is the headgasket, well then im not sure lol.
But from what I see, its 99-100 % being the oil seal. Either way, the tear down is the same lol
Thanks again
Old Oct 15, 2006 | 02:42 AM
pimpberetta
Gotter done today. 3 hours, not bad I thought.
The oil seal was popped out of the socket, but showed no signs of actually being bad. It honestly looked exactly the same as the new one.
End story, the leak always been there, the small amount of oil on the filter all the time originated from the cam seal leaking slowly.
