EGR solenoid - fix or not?
Old Oct 13, 2006 | 02:25 PM
cptdog's Avatar
cptdog
Default EGR solenoid - fix or not?
The mechanic says I need a new EGR solenoid for my 96 Neon. He says I can wreck my engine if I don't. I am getting sick of sinking money into this car though. Can anyone tell me if it is worth fixing? How long beofre this causes major problems if left unattended?
Old Oct 13, 2006 | 03:58 PM
spudsterier's Avatar
spudsterier
Default RE: EGR solenoid - fix or not?
you could replace it....or remove it completely
just get one from a junk yard for cheap if you dont wanna spend too much money
Old Oct 13, 2006 | 05:58 PM
das2123's Avatar
das2123
It wont wreck your engine, but can cause bad gas milage. The EGR valve and transducer should be changed at the same time.
Old Oct 13, 2006 | 06:24 PM
NEONRT98's Avatar
NEONRT98
If you dont have E-check, just take the damn thing off and block it.. Much much cheaper...
Old Oct 13, 2006 | 06:59 PM
das2123's Avatar
das2123
Keep in mind that while blocked off, you will have the CEL for a Code 32 unless you have an aftermarket PCM.
Old Oct 13, 2006 | 07:08 PM
NEONRT98's Avatar
NEONRT98
I think that may be my next step after I get the tail lights I saw on Ebay I liked...
Old Oct 13, 2006 | 07:21 PM
spudsterier
im gonna block mine off when i get to putting the turbo on....i alredy have a check engine light that never seems to go off and every neon ive ever owned has always had the check engine light on.....the only way i knew sumthing was wrong with the car was when the light actually went off
Old Oct 13, 2006 | 08:20 PM
FyreDaug's Avatar
FyreDaug
Theres no way to block it off and trick the computer into not getting a CEL? Like a resister or something?
Old Oct 13, 2006 | 08:48 PM
das2123's Avatar
das2123
ORIGINAL: FyreDaug
I know with Vitor's block-off kit he includes a resistor that is supposed to reduce the frequency of the CEL coming on. It's worked for some, not for others.
