Thats what i wan't i want damn close to no show with alot of go but it still needs to be my DD. What to do? And what are the first suspension mods i need to make to my stock car? 1997 4dr dohc atx
i wanted to get an old beat up neon and do the engine all up in it...but if im gonna do all that work to the motor then i dont wanna put it in a car that wont hold up...
im not gonna fix my fenders or front bumper for a while, all money into the motor
ORIGINAL: cjparker12345
Need to swap in an MTX if you want any decent power out of it, if you are staying N/A. If not then you could turbo the car.
As far as suspension goes, get some sway bars on there, stock or Eibach, and put some Eibach lowering springs on as well and see how much better it handles. If you have the money, I would HIGHLY recommend the Koni struts as well. If you can't afford those, then get some KYB's.
thanks a lot for the information. yea always wanted a turbo car but still dont know all that i will have to do with out buying a kit. just putting one on a stock one out of another car? what do i do?
You can put on the SRT-4 turbo...look up Spudsterier's post about it.
at low boost the internals should be fine....since im gonna want to run about 15psi, im gonna get new pistons and rods....so it all depends on what your wanting out of it
