suspension questions
Old Oct 18, 2006 | 12:10 AM
andy16's Avatar
andy16
Default suspension questions
Hello,
I'm new to the board and I drive a '96 base ATX neon. I've looked around for a while now and cannot find an answer to my questions so here thay are:
1. I'd like to lower it SLIGHTLY, maybe an 1", just enough to get the top of the tires parallel with wheel wells. I was considering the Mopar ACR/RT springs. As I understand it, these are stock springs, but the shortest springs they made. I hear that the earlier cars don't drop as much as the later, and considering the only options on my car are auto (sigh) and airconditioning, it probably won't be noticed. I was just wondering if anyone can confirm this that has tried it.
2. The main reason I considered these is that I'd like to change the suspension to RT specs. So if someone has a picture of the rear anti-roll I'd like to see it, since I need a bracket to put a bar on, but I'm not sure what the bracket looks like. (I'm scrounging through junkyards for one)
3. I also need new struts. On neons.org it says that the SDE (sport coupe/RT) struts are "stiffer", now obviously any junkyard struts will be shot just like mine, so does anyone know a good substitue?
thanks
Old Oct 18, 2006 | 01:12 AM
spudsterier's Avatar
spudsterier
Default RE: suspension questions
good substitute for the struts would be KYB GR2's.....they are inexpensive and perform well....
stock r/t struts are mcphersons....stock acr struts are koni's
i wasnt awary that the r/t's springs are shorter....as far as i knew just the struts were different
you will need the brackets for the sway bar that hold it to the car, and that hold it to the struts....if no one puts up a pic, then i will take a pic of mine tomorrow
Old Oct 18, 2006 | 01:38 PM
das2123's Avatar
das2123
ORIGINAL: spudsterier
95-96 ACR's have Arwins...97-99 ACR's came with Koni's
They aren't shorter, just stiffer.
Mopar High Rates give you about a 1" drop, but you will be lucky if you find any as they have been discontinued. You don't have tohave the R/T springs to get the roll bar.
Old Oct 18, 2006 | 04:13 PM
95neonriceeater's Avatar
95neonriceeater
he might be talking about these...
http://www.mopar.com/m_perf_subcat2C...=1161191530257
i was thinking about getting them for my neon
Old Oct 18, 2006 | 06:17 PM
das2123's Avatar
das2123
^^^Link doesn't work.
Old Oct 19, 2006 | 01:22 AM
95neonriceeater
damn it
it's just the r/t / acr springs
they are like 73 for the frotn and 73 for the rear
Old Oct 19, 2006 | 03:39 AM
andy16's Avatar
andy16
http://www.mopartsracing.com/parts/neon.html
5007001 ACR/RT level front 59.95
5007002 ACR/RT level rear 59.95
These are the springs I'm talking about. Somewhere I've read that for different equiptment levels, different spring heights were used instead of different rates. For example, a car with A/C would have more weight on the front, right side (I think it's the right) than a car w/out A/C. So to match the ride height, a taller (when unloaded), otherwise they are 150lbs. in. in front and 120 in back (ACR/RT and sport models) standard suspension is 140 and 120.
Old Oct 19, 2006 | 05:02 AM
95neonriceeater
well out of the acr/rt, high and x high springs
which ones are the best?
i think i will get these instead of eibach ones..hahah
MOPAR!
Old Oct 19, 2006 | 09:55 AM
spudsterier
wanna buy some stock r/t springs????
Old Oct 19, 2006 | 01:06 PM
das2123's Avatar
das2123
ORIGINAL: 95neonriceeater
Depends on what you want...if you want more comfort then the R/T's are better...if you want a stiffer ride thats lower, then the X-High rates are the best.
