engine swap gen1 to gen2
Old Oct 18, 2006 | 08:11 PM
dartgts's Avatar
dartgts
Default engine swap gen1 to gen2
Help! I have a 96 neon with the SOHC and auto, my son ran it out of oil and blew the engine. I found an engine/trans out of a 2000. Does anyone know if i can use this combo. Any guidance would be appreciated!
Old Oct 18, 2006 | 09:35 PM
speedomleedom_69's Avatar
speedomleedom_69
Default RE: engine swap gen1 to gen2
You would have to change the motor mounts and more likely to change the ECU, maybe the axel.
Old Oct 18, 2006 | 11:20 PM
spudsterier's Avatar
spudsterier
possibly the engine and car wire harnesses too
Old Oct 19, 2006 | 12:32 AM
das2123's Avatar
das2123
It will swap, but if the tranny is an auto 4-speed, then you can't use it. Most of the sensors should fit the harness but you may have to cut and splice some wires together. It would be easier to use a 97-99 engine.
