wires
Old Oct 19, 2006 | 04:54 PM
95neonriceeater's Avatar
95neonriceeater
Default wires
what are some good wires to get?
Old Oct 19, 2006 | 05:34 PM
ZiggyNeon's Avatar
ZiggyNeon
Default RE: wires
first off need to say what kind of wires like spark plug wires, speaker wires, general wire, ect
Old Oct 19, 2006 | 08:40 PM
dj_mars's Avatar
dj_mars
Default RE: wires
spark plug wires i have accel spiral fero 8 mm get them for bout 70 bucks work great but msd have these 10.5 mm if u gonna run huge volts to the plugs
Old Oct 20, 2006 | 03:04 AM
das2123's Avatar
das2123
Default RE: wires
MAGNECOR WIRES
Old Oct 20, 2006 | 03:11 AM
FyreDaug's Avatar
FyreDaug
Default RE: wires
stock wires will work just fine... People underestimate wires too much, the amount of money you will spend on those will give you gains elsewhere
Old Oct 20, 2006 | 05:16 AM
95neonriceeater
Default RE: wires
well my stock wires have over 240000 miles on them
everythign but the muffler, tb, head gasket and clutch have that many miles on it
Old Oct 20, 2006 | 05:35 AM
FyreDaug's Avatar
FyreDaug
Default RE: wires
Go with whatever is cheaper, a good aftermarket name or dodge replaceement, either way the spark will get there and ignite the airfuel the same
Old Oct 20, 2006 | 11:03 AM
spudsterier's Avatar
spudsterier
Default RE: wires
unless you have msd ignition and need wires that can handle a stronger current for the spark
Old Oct 20, 2006 | 11:17 AM
das2123's Avatar
das2123
Default RE: wires
ORIGINAL: FyreDaug
Magnecor's are lifetimed gauranteed though. I know cheapy autozones aren't.
Old Oct 20, 2006 | 11:33 AM
spudsterier
Default RE: wires
i had the 8mm MSD's on my car and they worked great
