Old Oct 22, 2006 | 08:22 PM
HabitatHxC's Avatar
HabitatHxC
Default RE: ?
Or you could use rice and it would be more of a glass bead effect.
Not kidding either.
Old Oct 22, 2006 | 09:14 PM
NEONRT98's Avatar
NEONRT98
Default RE: ?
ORIGINAL: HabitatHxC
Not kidding either.
What??
Old Oct 22, 2006 | 11:03 PM
IGottaFreeNeon's Avatar
IGottaFreeNeon
Default RE: ?
Is that sea foam stuff dangerous for your engine at all?
Old Oct 23, 2006 | 12:05 AM
spudsterier's Avatar
spudsterier
Default RE: ?
sea foam is perfectly safe for any engine
Old Oct 23, 2006 | 01:32 AM
das2123's Avatar
das2123
Default RE: ?
ORIGINAL: spudsterier
i have heard of some people experiencing sensor problems afterwards, most are fine though.
Old Oct 23, 2006 | 03:20 AM
HabitatHxC's Avatar
HabitatHxC
Default RE: ?
Yes rice... Doesnt damage sensors either it just floats along out of the exhaust after it has knocked a bunch of carbon off the pistons and valves.
Old Oct 28, 2006 | 02:37 PM
IGottaFreeNeon
Default RE: ?
I can't SeaFoam anywhere. But I did find some stuff called B-12, it says on the container that it will fix all the stuff SeaFoam will. But I'm a little leary about anything that has more precautions than instructions listed on the container. Have any of you ever used it and if so did it work, or will I be replacing parts in a couple hundred miles from now.
Old Nov 2, 2006 | 02:30 AM
rattdog1's Avatar
rattdog1
Default RE: ?
can sea foam be left in the tranny till my next fluid change?
Old Nov 2, 2006 | 02:41 AM
das2123's Avatar
das2123
Default RE: ?
ORIGINAL: rattdog1
NO!!!!
Old Nov 2, 2006 | 11:01 AM
rattdog1's Avatar
rattdog1
Default RE: ?
called dodge and they said i can leave it in,other people say its not good too,just had the fluids changed prior to dumping this stuff in,just trying to do the right thing....
