srt 4 swap in my 99 rt
Old Oct 24, 2006 | 10:10 PM
rtneon's Avatar
rtneon
Default srt 4 swap in my 99 rt
im bout to do a srt 4 swap in my 99 rt i need to know what all i need to do it right like what computer and all to use im planing on doing tons of motor work after i get it in the car and running and i would like to kno what is the best way to go
Old Oct 24, 2006 | 10:39 PM
Whatsrt4's Avatar
Whatsrt4
Default RE: srt 4 swap in my 99 rt
I'm in the middle of doing that swap right now,what a pain in the ***(I can say that here can't I).I would sudjest getting your engine as complete as poss from the start.I started with a short block and needed way more parts than I figured I would.You will need a custom made passanger side motor mount an alt mount from a pt cruiser + some spacers for ps pump.You will also need a new clutch,probably go to non modular setup,one that can handle 300+ hp & 325 lb ft torque at least.While your at it you might as well go with an aftermarket intercooler (larger)+ all custom pipes .I'm going with a stand alone engine management system (microtec) set up by a local shop on dyno.(about $2200) ouch I know but worth it if I want further mods later. All told I think I'm in for about $5000.00. Good luck There are other ways to do it cheaper,and lots of info out there
Old Oct 24, 2006 | 10:47 PM
rtneon's Avatar
rtneon
thanks for the info i was wondering about the stand alone engine management system if i would need one or not if i use one of them do i need to use the srt4 computer or can i use the one i got now do u kno any other things i would need other then the motor abd the motor mounts i know for the 2.4 motor not the srt4 one u need a bigger clutch i was going to go with a bigger intercooler im really worried about what i need to get it in the car to make it run
Old Oct 25, 2006 | 02:45 AM
ZiggyNeon's Avatar
ZiggyNeon
easiest parts list is a totalled srt4 that still runs
Old Oct 25, 2006 | 10:55 AM
spudsterier's Avatar
spudsterier
atleast then you wouldnt have to go shopping for sumthing that you might find out you need later
Old Oct 26, 2006 | 04:26 AM
Whatsrt4's Avatar
Whatsrt4
I think you will need the stock computor to get the guages to work.I've heard it's quite a chore to get the srt comp to work with 1st get car.I can let you know more when mine is done
ORIGINAL: rtneon
Old Oct 26, 2006 | 12:55 PM
das2123's Avatar
das2123
ORIGINAL: Whatsrt4
Are you talking about using the stock 1st gen PCM??? No way will that work. You will need a NEW SRT-4 PCM.
Old Oct 27, 2006 | 12:09 AM
rtneon's Avatar
rtneon
well i kno the first gen comp wont work but what is the best way to go with the computer
Old Oct 27, 2006 | 12:12 AM
das2123's Avatar
das2123
ORIGINAL: rtneon
I just said you would need a NEW SRT-4 PCM...stock or upgraded (doesn't matter). It has to be new because if was installed on the SRT-4 then it has seen sentry and won't work on the 1st gen neon.
Old Oct 27, 2006 | 01:21 AM
rtneon's Avatar
rtneon
well what the best way to go with a tranny will the srt4 tranny fit in a 1st gen
