SOHC to DOHC Question
RE: SOHC to DOHC Question
you also need coolant lines that run from the engine to the heater core. the SOHC are diff then the DOHC. mine was rottin out so I got a way better one from the junkers an they run differently. so I went bak to exchange it, I have a DOHC an I noticed the SOHCs run under the intake close the head, while the DOHC goes rite under the intake chamber thing
