t the front do the lowering springs
Old Oct 29, 2006 | 07:42 PM
javon's Avatar
javon
Default t the front do the lowering springs
i have sone lowering springs i am trying to figure out which end goes up and down its for a 1995 at the front do the smaller end of the coil go up or down at the back is it the same way or diffrent thanks
Old Oct 29, 2006 | 10:29 PM
spudsterier's Avatar
spudsterier
Default RE: t the front do the lowering springs
the backs are fairly easy if you look at it.....the smaller end goes at the top, it should fit right about the rubber ring at the bottom of the mount.....i think the front is the same way, big end at the bottom
Old Oct 30, 2006 | 12:05 AM
javon's Avatar
javon
does anybody know for sure if the maller end of the spring goes at the top on the front and back i know at the back the smaller part goes at the top is it the same way for the front or smaller end goes at the bottom for the front
Old Oct 30, 2006 | 12:25 AM
spudsterier
like i said.....big end is at the bottom
