ok . i have a 98 rt with a 5 spd. about every three or four stops i make the car shuts off. it starts right back up when i turn th ekey but its getting old. please leave input.
sounds like some type of vac leak. check the vac hose that runs from the brake booster to the eng. other than the stalling it runs ok? good mpg? codes?
your prolly right bc i did the code trick with the cel and got a 12 and 31 or 32 code i dnt tremember wich. but yea it run fine. i need a throw out bearing but thtas it. thanks.
the gas cap wasnt on tight. so will that kill the 31 code? if i tighten it?. also wich vacume lines should i check? will the sohc and dohc crank pulleys interchage?
