out my exhaustwhite smoke
Old Oct 30, 2006 | 11:35 PM
javon's Avatar
javon
Default out my exhaustwhite smoke
when i sit at a stop light and pull off there is white smoke blows out my exhaust and it smells real bad well if this helps i could not pass emission could it be my cat or head going out i did a tune up and still bloeing white could some body tell me what this could be
Old Oct 31, 2006 | 12:01 AM
neoncrazy101's Avatar
neoncrazy101
Default RE: out my exhaustwhite smoke
sounds like it could be a head gasket.
Old Oct 31, 2006 | 12:08 AM
javon's Avatar
javon
what are signs of head gasket going out wikk it be better for me to replace the gasket or get a new motor and how long could i drive on a bad head gasket
Old Oct 31, 2006 | 12:34 AM
neoncrazy101
when u check your oil if u see what seems to be chocolete milk in it or if u check the coolant level from the cap and u see like a oily substance or chocolet milk then it is... head gasket...depends on how many miles you have on it or how long u plain on having the car. you might want to check first though to see if it has the MLS gasket... i cant remember where the flange is from i think its between the intake tubes 1 and 2 there should be like a flange type thing and if u have that then the gasket has been replaced before and it shouldn't of broken but then again its a mechanical machine.
Old Oct 31, 2006 | 01:54 AM
winsettz's Avatar
winsettz
http://www.myneonspeed.com/howto/how...en_mls_prn.htm
How to recognize an MLS headgasket.
Old Oct 31, 2006 | 05:38 AM
FuzzRacer's Avatar
FuzzRacer
never drive on a bad Head gasket, even if it is the MLS gasket, and it doesn't matter the how long you drive on it, letting the head get hot is to much, because then after you stop driving it, the head cools and with all the heating and cooling down your definatley going to crack the head which will cost you more in the end, some other signs are: your anti-freeze resevouir bubbles, your heat may turn luke warm to cold to luke warm again untill finally it's just cold air. and as far as fixing it, you could do it if your inclined, just make sure you grab the MLS kit, but if you take it somewhere else, shop around for prices and remember if you have the DOHC it's gona cost you more to fix Good Luck !!
Old Oct 31, 2006 | 05:54 AM
95neonriceeater's Avatar
95neonriceeater
once you have signs of it messing up
change it like he said
my water pump blew cause my engine got too hot
Old Oct 31, 2006 | 02:57 PM
FuzzRacer's Avatar
FuzzRacer
My oil switch went out after my head cracked, luckly I was right around the corner from where I live, I looked like a traveling cloud lol.
Old Oct 31, 2006 | 04:10 PM
95neonriceeater
hahaha
my engine is fine
it was only leaking at a little part that was only about an inch long
maybe not even an inch
my dad and i laughed when we saw it
