Is this an E Z fix?
Old Nov 1, 2006 | 04:44 PM
hnda8r's Avatar
hnda8r
Default Is this an E Z fix?
I actually have two codes, they are: 21, 51.
21= I must replace the two oxygen sensors
51= Im going to replace the fuel filter for now then maybe the pump when the funds come around.
My questions are how hard/easy is it to replace these items. Is the fuel filter inside the fuel tank? Can the average Joe do this kind of maintenance? Thanks guys.
Old Nov 1, 2006 | 04:46 PM
95neonriceeater's Avatar
95neonriceeater
Default RE: Is this an E Z fix?
get the money for the pump or you're going to develop an even bigger problem
Old Nov 1, 2006 | 04:53 PM
hnda8r's Avatar
hnda8r
Ok....you didnt really answer my questions. But I will replace the whole thing. How hard is it to replace the 2 oxygen sensors and the pump/filter?
Old Nov 1, 2006 | 04:59 PM
95neonriceeater
if you read thoughs manuals everyone has been saying to get
it shouldn't be that hard at all
Old Nov 1, 2006 | 05:23 PM
NEONRT98's Avatar
NEONRT98
I do beleive the fuel filter is on the outside of the tank... so that wont be entirely too hard to do.. just dont do it with a full tank ;-) and depressurize the lines before you do it!
The pump is inside the tank and would require a bit more to replace.. yo uhave to actually drop the tank to get to it...
The O2 sensors are easy. I would suggest checking all your connections, checking for frayed wires at the connectors also... If you get the special socket to get the sensors out, its not taht hard...
Hope this helps!
Old Nov 1, 2006 | 05:40 PM
das2123's Avatar
das2123
You won't need to change the downstream O2 sensor just the upstream one located on the exhaust manifold. There is a special socket that makes it easy to change.
If you change the pump, get a Walbro pump. They are cheaper than the stock one from the dealer.
Old Nov 1, 2006 | 06:06 PM
hnda8r's Avatar
hnda8r
2 more question for ya das2123, can I get that special socket at my nearest autoparts store? As far as the Walbro pump, where can I get one of those? Thanks.
Old Nov 1, 2006 | 06:19 PM
das2123's Avatar
das2123
ORIGINAL: hnda8r
1:Yes, you can get it at autozone, NAPA and places like that. It has a slot down the side for the wires and is a deep socket.
2:Try Modern performance or ebay
Old Nov 1, 2006 | 07:00 PM
FyreDaug's Avatar
FyreDaug
Though I dont understand why its neccesary to get a special tool. You could just use a wrench, assuming your have the space back there (removed air box?) Im doing my upstream one this weekend I think. Im not getting any codes, but its in hope to fix the high idle (which seems to be going away slowly, but its still there time to time without any codes). I'll see how it looks, ill be replacing it anyways but if its real bad maybe ill change the other one too. Or atleast put the wire brush to it to clean it off. The downstream one I believe you need to lift the car up to get access to it, it is after the cat though
Old Nov 1, 2006 | 07:11 PM
hnda8r's Avatar
hnda8r
Thanks you guys for all the help. I will most likely change both this weekend, as for the pump Ill be keeping my eyes open for any good prices on a walbro pump.
