Enigine moves a lot.
Old Nov 2, 2006 | 08:30 PM
thaguamanian's Avatar
thaguamanian
Default Enigine moves a lot.
I installed new motor mounts. i think that there's 3:
front
front right
torque
-but yet my engine still jerks when i shut off the engine. what is the problem?
Old Nov 2, 2006 | 10:30 PM
spudsterier's Avatar
spudsterier
Default RE: Enigine moves a lot.
the engine should move a little
pimpberetta's Avatar
pimpberetta
Well there is 3 motor mounts yes.
Engine to frame, tranny to frame, and the front of the engine to the frame. Not sure what you mean by torque. On the MTX there is a bobble strut, perhaps your refering to that.
My engine wobbles also alot, due to the rubber mounts and no bobble strut as I dropped an MTX in without the bobble.
I really wouldnt worry about it that much, there suppose to move.
But if its that bad, maybe go with solid motor mounts.
Old Nov 3, 2006 | 12:11 PM
ZiggyNeon's Avatar
ZiggyNeon
ORIGINAL: pimpberetta
if you go with solid mounts no need for the bobble or mtx kmember
Old Nov 3, 2006 | 06:42 PM
NEONRT98's Avatar
NEONRT98
Did you replace the mounts or get the urethane inserts??
If you replaced them with the stock mounts: You will get some movement still because of the rubber in the mount...
If you used inserts: Make sure they are tight in there.. there shouldnt be too much movement.. but more noise in the cab
Old Nov 3, 2006 | 07:11 PM
spudsterier
i like how my solid front mount makes the car shake when its stopped
