Old Aug 6, 2015, 11:47 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Headlight switch not engaging the headlights
Old Nov 3, 2006 | 12:03 AM
FuzzRacer's Avatar
FuzzRacer
Default Headlight switch not engaging the headlights
Did a search came up with nothing. before when I pulled the headlight *** I had to jiggle it a bit to get them to stay on, well now when I pull it out and jiggle some they just don't work period, my brights won't even work when pushed foward, I have to pull the bright beam lever back and hold it to get them to stay on. but my park lights still work. the bulbs aren't blown and neither are the fuses. I jiggled the headlight connectors around to see if I had a short but got nothing. I think my headlight switch is bad and just wanted to confirm. but would that cause my brights to do the same thing as well ? Do I have some wire tracing ahead of me? any help would be appreciated thanks everyone !!!!
Old Nov 3, 2006 | 12:07 AM
FastNeon84's Avatar
FastNeon84
Default RE: Headlight switch not engaging the headlights
i had the same problem you did man. at first i thought it was this cold weather...but all i did was replace all my headlight fuses in the car and thhe engine bay, and now mine works fine. try that to see if anything changes.
Old Nov 3, 2006 | 12:19 AM
FuzzRacer's Avatar
FuzzRacer
Ran out and tried it and still no lights unless I hold in the bright lever. Thanks though !!
Old Nov 3, 2006 | 01:24 AM
spudsterier's Avatar
spudsterier
sounds like you need a new dimmer/turn signal switch
Old Nov 3, 2006 | 01:38 AM
winsettz's Avatar
winsettz
Was about to suggest that the switch was getting old or perhaps one of the contacts is loose? Open it up and see?
Old Nov 3, 2006 | 02:08 AM
FuzzRacer's Avatar
FuzzRacer
thanks guys, I have the column cover off now but its too cold and I don't feel like messing around with it with the flashlight lol, im gona check the switch out tomorrow and see if maybe one connectoions just simply has no touch. would I be able to solder the connections? looking at the haynes manual it might be doable
Old Nov 3, 2006 | 10:10 AM
spudsterier
i bought a neon once that had the same problem....after looking at it i noticed that the whole bottom of the switch and the plug were melted together.....ugh....
i would personally just buy a new switch....then you wont have to worry about it again for a while
Old Nov 3, 2006 | 12:07 PM
ZiggyNeon's Avatar
ZiggyNeon
not to mention after you replace that you wont have the neons left turn signal problem anymore
Old Nov 3, 2006 | 12:24 PM
FastNeon84's Avatar
FastNeon84
ORIGINAL: ZiggyNeon
lol u have that same problem too??? man ive always wondered why my left turn signal would never automatically turn off after making a turn.. for some reason itdidnt happen til i lowered my car tho...so i thought that was the problem...i guess i need to also replace that switch!
Old Nov 3, 2006 | 12:46 PM
ZiggyNeon's Avatar
ZiggyNeon
yeah they cut corners with that switch when you replace it, it wont come on ne more when you depress the brake lol and what not...
