Neon Header
Old Nov 6, 2006 | 08:21 PM
Megalomaniacal's Avatar
Megalomaniacal
Default Neon Header
what headers do you guys have on your neons? im planning on getting a new header this friday but i have no idea which ones are good.
post pics if you have 'em
also, if you have a new header, did you install it yourself? if not, how much did it cost to get it done?
Old Nov 6, 2006 | 08:26 PM
spudsterier's Avatar
spudsterier
Default RE: Neon Header
they arent had to install....most of the time...
i have a pacesetter shorty header that was on my old r/t......now it hangs on a hook in my garage
Old Nov 6, 2006 | 09:20 PM
HabitatHxC's Avatar
HabitatHxC
I have a short DC sport in my trunk, because i dont have 60 bux an hour to have it installed... I could do it myself, and have a friend do some welding... but its getting cold out!
Old Nov 7, 2006 | 06:27 PM
Megalomaniacal
anyone with pics?
Old Nov 7, 2006 | 06:54 PM
95neonriceeater's Avatar
95neonriceeater
i'm going to get a pacesetter header from modern performance soon
but im pretty sure someone on here has a pic of theirs...
Old Nov 7, 2006 | 07:01 PM
das2123's Avatar
das2123
Pacesetter header is the best for a SOHC. If you have a DOHC, then a Longtube header would be ideal as long as you don't have emissions check, because it deletes the cat converter.
Old Nov 7, 2006 | 07:09 PM
95neonriceeater
after my neon runs again im getting a high flow cat...
I'LL GET POWER EVEN WITH EMISSIONS!
Old Nov 7, 2006 | 07:19 PM
das2123's Avatar
das2123
I just don't believe that a high flow cat will make that much of a difference on our neons. I could be wrong though.
Old Nov 7, 2006 | 07:37 PM
95neonriceeater
well i'll tell you guys when i put one on
Old Nov 7, 2006 | 11:30 PM
FuzzRacer's Avatar
FuzzRacer
I have the Pacesetter short tubes. I dont have a cat either, replaced that with a high flow. Didn't think about the long tubes till it was too late but still gets the job done, ill take some pics in a sec and post them
