Shifting.
Old Nov 7, 2006 | 10:44 PM
lateralus823's Avatar
lateralus823
Default Shifting.
95 neon ATX. Sometimes when i go to shift into drive from reverse or just 1st to 2nd my car sort of lunges forward a little bit its not always it usually only does it if my rpms are lower and its not really a hassle id just like to know if its something serious.
Old Nov 7, 2006 | 10:51 PM
NEONRT98's Avatar
NEONRT98
Default RE: Shifting.
Personally, I dont know about the ATX neons much... but I did have an ATX Camaro... and when I went from any gear to like.. 1st from a stop, it would lunge forward or kinda jerk a bit...might be normal
Old Nov 7, 2006 | 11:14 PM
lateralus823
Yeah it does it going into reverse and park :S, like once you shift it its like it like lunges forward a bit
Old Nov 8, 2006 | 12:31 AM
das2123's Avatar
das2123
Check your fluid level and when was the last time you had a fluid and filter change? You should do it every 30,000 miles.
