new motor
Old Nov 8, 2006 | 06:34 PM
javon's Avatar
javon
Default new motor
i have a 95 sohc and my motor just went out would it be ok if i put a 2000 model motor in and would it be hard to swap them
Old Nov 8, 2006 | 06:39 PM
winsettz's Avatar
winsettz
Default RE: new motor
You're probably going to need more than the motor...
Old Nov 8, 2006 | 06:56 PM
das2123's Avatar
das2123
You may run into some sensor compatibilty issues, but it will swap in and fit just fine. If you run into sensor plugs issues, just cut the wires, solder and wrap them up.
Old Nov 8, 2006 | 07:18 PM
javon's Avatar
javon
so would i still be able to put a air intake on
Old Nov 8, 2006 | 07:21 PM
hnda8r's Avatar
hnda8r
sure why not
Old Nov 8, 2006 | 07:51 PM
das2123's Avatar
das2123
ORIGINAL: hnda8r
sure why not
He's probably asking because the TB is mounted differently on the 2nd gens.
You won't be able to use the 1st gen intake, but you should be able to use a 2nd gen.
Old Nov 8, 2006 | 10:08 PM
NEONRT98's Avatar
NEONRT98
The mounts and everything are located the same??
Old Nov 8, 2006 | 10:56 PM
das2123's Avatar
das2123
ORIGINAL: NEONRT98
The same as the SOHC.
Old Nov 8, 2006 | 11:54 PM
spudsterier's Avatar
spudsterier
only for the 2000 year
Old Nov 9, 2006 | 03:23 AM
das2123's Avatar
das2123
ORIGINAL: spudsterier
Yes you are correct.
