What oil in manual Tranny?
Old Nov 13, 2006 | 04:32 AM
mjd38659's Avatar
mjd38659
Default What oil in manual Tranny?
I just picked up a 96 Neon for $1500 yesterday and I have a stupid question. What are you supposed to run in the manual transmission? I looked in a repair manual and it just said Mopar manual trans fluid or equivelant. I have to change out an axle seal and don't want to mess anything up. Thanks!
Old Nov 13, 2006 | 06:42 AM
FastNeon84's Avatar
FastNeon84
Default RE: What oil in manual Tranny?
uhm to my knowedge...the only oil that goes in the tranny for the 96 neon is Gear oil..
Old Nov 13, 2006 | 07:19 AM
mjd38659's Avatar
mjd38659
Thats what I thought. Bought some 80w90. Just wanted to double check before I tore it down. THanks a lot!
Old Nov 13, 2006 | 11:09 AM
spudsterier's Avatar
spudsterier
yeah i always use penzoil 80/90 gear lube or the super tech 80/90 (walmart brand) and never had a problem
Old Nov 13, 2006 | 11:44 AM
das2123's Avatar
das2123
ORIGINAL: spudsterier
Don't you keep burning up trannies??
Redline is a cheaper substitute to the Mopar fluid.
Old Nov 13, 2006 | 04:29 PM
spudsterier
nope...
this is the first one in this car, and i only put about 1/2 quart of that fluid in there from when i hit the semi a broke the axel.....the way i figure it is that the tranny was gonna go out eventually since i drive it real hard and the previous owner used it for autocrossing...plus 150,000 miles with that kind of driving isnt bad
my old car: i bent a shifting fork when i slammed it into 2nd while doing a bad *** burnout......2nd tranny, had almost 300,000 miles on it and didnt like climbing the mountains in pennsylvania[&:]
Old Nov 13, 2006 | 05:27 PM
racerx55's Avatar
racerx55
80w90 ia WAY too thick guys, its supposed to have something with the thickness of ATF in it, gear oil will cook it on a long highway drive, i know from experience[:'(] plus you lose power from the tight clearences trying to shove that thick crap between the gears
that royal purple stuff works wonders, use synthetic 5w30 motor oil is it has alot of miles or abuse, the chrystler fluid is like **** water
Old Nov 13, 2006 | 07:46 PM
spudsterier
in a manual trans????
