cam and engine
Old Nov 16, 2006 | 04:22 PM
blindbakerdude's Avatar
blindbakerdude
Default cam and engine
i have a 97 sohc and i want to get a racing cam what do you suggest
i also wanted to know if i can put the v6 from a dodge caravan in my neon and how would you go about doing that
Old Nov 16, 2006 | 04:27 PM
spudsterier's Avatar
spudsterier
Default RE: cam and engine
its possible but would be alot of work......
get a crane #12 or #14 cam for more go
unless you want just a little more power then get a stock cam from a 95
Old Nov 16, 2006 | 05:00 PM
95neonriceeater's Avatar
95neonriceeater
the mopar performance cam (stock 95 cam) was shown for a 4-6hp increase and is around $140
the crane cams are a lot bigger and probably show ever more of an increase and are $250
so it's up to you and how much money you're willing to spend
and if you get the crane cams you might as well start looking into porting your head/intake manifold
Old Nov 16, 2006 | 06:04 PM
HabitatHxC's Avatar
HabitatHxC
Is porting nessisary for the crane cams? cause im thinkin of getting one... i like the sounds mine makes... but i want a more dramatiic lobe sound...
Old Nov 16, 2006 | 06:15 PM
FyreDaug's Avatar
FyreDaug
ORIGINAL: 95neonriceeater
you could find a 95 at a wrecker and get the came for probably 40 bucks, then spend the money on a cam gear. Thats a different way of spending the money, and a port match on that should be good for a decent amount of power
Old Nov 16, 2006 | 07:21 PM
spudsterier
porting isnt necessary...however upgraded springs are
Old Nov 17, 2006 | 04:28 PM
blindbakerdude
whats the difference from the 95 and 97 cams
Old Nov 17, 2006 | 04:40 PM
streetbikr600's Avatar
streetbikr600
if i get a mild mopar performance cam, would it rase the smog numbers a lot or would i still be able to pass smog
Old Nov 17, 2006 | 07:54 PM
spudsterier
the 95 cam is supposed to be a slight bit more aggressive....
dont know about smog though....but i think it would still pass
Old Nov 18, 2006 | 01:35 AM
95neonriceeater
the 96-99 neon cams were i think around 7.4
the 95 i think is 7.9
and mine has passed smog every time i took it in
