Popping bushings from the shifter
Old Nov 19, 2006 | 03:11 AM
winsettz's Avatar
winsettz
Default Popping bushings from the shifter
I got the two boogers on the tranny itself, and when I try to put em on the shifter the bushings are being a real hassle and refuse to separate. I've tried using two screwdrivers to pop it out, but not particularly successful.
Old Nov 19, 2006 | 04:27 AM
jdog08's Avatar
jdog08
Default RE: Popping bushings from the shifter
melt them????
Old Nov 19, 2006 | 10:40 AM
spudsterier's Avatar
spudsterier
ORIGINAL: jdog08
melt them????
wouldnt be a good idea since the surrounding is hard plastic if i remember correctly.....
however you could use a torch to heat them up so that they are more pliable.....then try to pop them out
