special puller needed?
ORIGINAL: spudsterier
i wasnt sure so i took a shot at it![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
in that case you need a 3 bolt steering wheel puller and some really thin/long bolts and a few washers....
are you changing the oil pump or removing the crank????
get the steering wheel puller.....
screw in the crank bolt a little bit and use it as the push point for the puller.....then as the gear is moving off just unscrew the bolt a little
