Gauge Cluster
Old Nov 22, 2006 | 01:48 AM
tay_ang's Avatar
tay_ang
Default Gauge Cluster
I have a 1996 dodge neon 2 dr 5 speed. My gauge in my car is in Km/h and it does not have a RPM gauge, as far as i know as long as i have the grey wire with a line on it behind my cluster I can plug in a cluster with a RPM gauge no problem. Now here is my question I have been wanting to swap my No tach cluster for one with a tach but the only other ones that I can find are in MPH if i installed the one that is in MPH will i have to worry about the speedo being accurate or is it just a direct plug and play, all gauges will read properly?
Thanks
Old Nov 22, 2006 | 01:58 AM
spudsterier's Avatar
spudsterier
Default RE: Gauge Cluster
its all just plug and play.....mph or kmph make no difference.....and all neons are prewired for a tech...just throw in the gauge with one and your good to go
Old Nov 22, 2006 | 02:24 AM
das2123's Avatar
das2123
ORIGINAL: tay_ang
Speedo won't be off and it's plug and play. You can swap the odometer out to keep your milage correct also.
